K8400 object moves, when it's small
When printing an object with diameter from 1,5cm, it loosens from the plate when it has 2 - 3mm thikness and it’s not possible to continue printing that way.
Is there some kind of glue that can be used to solve this problem?
thanks in advance,
Wim
You can make the bottom surface bigger by setting a so called brim. (In Cura configuration, Structures tab.) When the print is ready, remove the brim.
But I am using 3DLAC (it’s water soluble) on the glass plate with PLA and PETG and I am very happy with it.
Good luck
