K8400 Ignored dual extruder offset
Hi
I am using the k8402
Repetier host and slicer CuraEngine
I want to print supports in a separate material, but the object and the support are x 23.7 mm apart.
In printer settings in repetier host the value for x offset is -23.7
but the value is ignored.
I have tried to put the value to 0 and even +23.7 with no difference.
Please advise.
/Stefan
Did you reslice after setting the value?
Hi!
I am sorry, but it just works now :slight_smile:
I cant answer on what i did :frowning:
But thanks for a Quick answer!
Things like this happen to me as well. Similar to the issue print from Ext. 2 only from SD card.
I’m quite sure this happens whenever I switched to extrude 2 in the manual control section ie. to test the flow of fillament. Solution: go to manual control, choose extrude 1 and do some action.then go ahead with your job
