Once the firmware uploaded you must go to the “Settings” menu on the LCD and select “Restore Failsafe” and click the button. Once this done go in “Settings” again, select “Store Memory” and click.
And you must use the 1.0.6 version of the Arduino software to upload the firmware and not the 1.6.x version which doesn’t work correctly with this firmware
[quote=“rj1”] should i upgrade the firmware to 1.4 ?[/quote]Certainly because it fixes an important bug.
Was your printer powered on when you took the picture of your LCD or only connected to the USB?
[quote=“rj1”]wat kan ik nu nog verder doen?[/quote]Sit and pray?
More seriously, no temperature is shown on your display (you should get the room temperature for head 1 -reading like 23/0°).
You should re-check the thermistor. To test it, unplug it from head 1 and plug it in the 2nd head therm terminal on the controller board. The temperature should now show on the left temperature display.
while assembling, i did the cables of the heater and of the sensor wrong.
So i connected the heater cables in the 2 middle screws, where normally the sensor cables should have been.
but then i read about it in the forum and i fixed it.
that’s why i thought that maybe the sensor is already damaged and that’s why i bought a new one, but still the same result.
To check if the Therm input is functioning properly, you can remove the plug of the thermistor and connect a 100k resistor or potentiometer to this input on the controller board. With 100K you should read a temperature about 20°. With a potentiometer you can see if the temperature changes when you turn it.
1.) I get 103kOhm from Thermistor
2.) I have wired connection from the 2 middle screws on the print head to the mainboard
3.) I installed new Firmware 1.4
Still I get the MAXTEMP Error I think everything else seams working, since I can do autohome with no problem.
For testing: Can I use the thermistor on the “bed-therm” connector?
Or can I install the dual head firmware and connect everything on the leftside of the print head?
[quote=“rj1”]Can I use the thermistor on the “bed-therm” connector?[/quote]You can : a temperature should show on the second line of the display. Or you can plug it on the H2-Therm output (no need to install the dual head firmware to get a display).
