K8400 do nothing and SD card doesn't work
I have completed my K8400 a few days ago.
Everything moves manually but it doesn’t print
I can see the commands in repetier going out with a OK
behind each line but the printer doesn’t move at all
extruder 1 is warming up but that’s all
the SD card reader doesn’t work either.
It’s frustrating !!!
Any help ?
Regards
Marc
The SD card.
There is a selection below “print from SD card”
Init SD card. Anytime you remove and replace the SD card you have to do this.
Printing: I have never heard of this.
Are you using this software?
https://www.vellemanusa.com/downloads/files/vertex/software/vertex-3d-printer-repetier-host-1-0-6.zip
I know but it doesn’t work
yes same software
You have more then likely done this but I will throw it out there anyway.
Have you tried a different SD card?
Are you putting Gcode files on the card?
The file name will end in XXXXX.Gcode.
Hi
Could you please post pictures of your motherboard?
VEL337
