First I had a problem with autohome because the cable of the Z endstop didn t work.
Got this fixed now. Autohome works, but the correction of the height of the platform does not.
Finally I cannot fasten the screw at all, it has reached its limit and the distance between the head and the platform has got bigger, not smaller. About 5 mm.
I tried to loosen the screw a few times with little effect too.
I could get the platform higher with the screws under it, but that is not the way tot do it, I guess.
sure !
I began with one turn and it seemed not to have changed a lot, another, some more
I alsoo tried to loosen the screw because I thought the manual was wrong, but no effect
Like i said before, now the screw has reached the end, cannot fasten it more and 5-6mm distance
not simple to make pictures, I checked the instructions, I screwed the calibration piece out and back in, I dont think there is a way to do this wrong. i do not know what you mean by ‘the flag for the Z end stop’
i repeated auto home, distance between nozzle and plate about 2mm (checked it with a folded paper)
every time I screw the calibration nut to the right the distance gets a little bigger
I will make some pictures but what are you going to see ?
