I installed a mk2 heatbed on my k8400. I used a power converter and additional power supply 12V 250W. After I installed it my auto home function did not work anymore.
If i select auto home it will just move all axis in one direction and not in the two like normally.
I have two printer so I swapped out the main board for troubleshooting purpose. Witch the other main board it works fine.
Is my original main board fried? Or is it a software or driver problem?
Will do this ass soon as I can, Find it strange it moves in one direction but not the other only in auto home.
If I home the printer (not the correct position after homing) I can move the printer with repetier or on the printer control both ways to the home point it took.
Did forget to mention when I plug in the main power but not the usb the printer start heating both extruders and the lcd doesn’t come on.
If I plug in the usb and the main power the lcd works fine and the printer doesn’t heat anything.
It is an new printer. The problem started after I installed the heatbed.
What could I have done wrong when I installed it? I used a pcu u and the power supply I mentiond in my first post. The heatbed is a mk2. Evereting was wierd like it is mentioned on wiki
