K8203
You can find the ini file for it here
http://www.k8200.eu/downloads/files/downloads/slic3r_175_pla_config.zip
I think this works with one of the later versions of Repetier.
The new driver supplied with the K8203 has twice steps in comparsion with the old driver. Have you replaced the old one with the new, K8200man? Maybe there is a problem with the Multiplicator?
I use extrusion width 0.35 mm and multiplicator 1 (the configuration file from Velleman sets extrusion width 0.40 and multiplicator 0.92, which was not perfect).
Just making the electronic and head interchangable now, switching the electronic to Rumba
I use the latest repetier host version which is not compatible to version 0.95.
By the way, dual extruder expansion is cooming soon.
:slight_smile:
[quote=“LCD”]The new driver supplied with the K8203 has twice steps in comparsion with the old driver. Have you replaced the old one with the new, K8200man? Maybe there is a problem with the Multiplicator?
:)[/quote]
Hi, I see I can purchase the dual extrude “setup” from here https://store.open-electronics.org/index.php?route=Double_extruder_3DRAG,
  • has velleman not offered such a setup?
    I have the K8203 now, z axis upgrade and it’s night and day. No more skidding on the feed bolt!!! What a a joy!!!
[quote=“Meximelt”][quote=“LCD”]The new driver supplied with the K8203 has twice steps in comparsion with the old driver. Have you replaced the old one with the new, K8200man? Maybe there is a problem with the Multiplicator?
:)[/quote]
    I have the K8203 now, z axis upgrade and it’s night and day. No more skidding on the feed bolt!!! What a a joy!!![/quote]
    I think, this will be offered by Velleman next year, because the Instruction for K8203 mentions dual Extruder upgrade. Still working on better cable management to upgrade to rumba and Diamond hotend (want to use its colour bleeding feature).
[quote=“LCD”][quote=“Meximelt”][quote=“LCD”]The new driver supplied with the K8203 has twice steps in comparsion with the old driver. Have you replaced the old one with the new, K8200man? Maybe there is a problem with the Multiplicator?
:)[/quote]
    I think, this will be offered by Velleman next year, because the Instruction for K8203 mentions dual Extruder upgrade. Still working on better cable management to upgrade to rumba and Diamond hotend (want to use its colour bleeding feature).[/quote]
Hi - just got thru my entire re-wiring of the system here! Did you ever experiment with dual extrusion or the Diamond Hotend? If so, how did you like it?
