I have recently installed the K8203 upgrade with, for me, disastrous results. I had several issues with the firmware but these were resolved through the forum – thank you. I eventually got the printer extruding but can print nothing.
The X and Y axes don’t move consistently. The Y axis in particular
Using Slic3r the Y repeatedly stops and then starts appearing to jump slightly making a clicking noise. The X axis also occasionally stop/starts.
Cura is little better but the symptoms are different. The Y axis jumps about 8mm forward and backward apparently randomly but with no sound.
I have flashed the firmware several times and downloaded the file twice. Restoring the EEPROM files each time. (Except on the first occasion when first tried printing - the results were no different)
A comparatively minor problem is that the fan doesn’t work. The light on the board comes on but there is no voltage at the fan. The fan is OK - tested with 12v supply.
The stop start actions turned out to be dependent on print direction. When printing X direction the X motor stop/starts 45 degree both. This was a new control board. My original one had a loose USB connector so I bought a new one for the upgrade. Got the old one repaired and replaced the new one, now works OK. Although disappointed with quality of print.
Yes 1.0.6 Flashed the firmware on to my old board and now runs OK. I’m returning the new board to the supplier for checking. I wonder if the uploading of the EEPROM settings is really reliable. What are the symptoms of failure at this step? The bead laid down by the direct drive is rougher than the gear drive. Is this because the individual steps of the motor are reflected in the output?
The fact that the control board worked with the stock hotend but not with the new one is very confusing.
I’m not sure where to go next.
Did you properly adjust the reference voltage for all of the stepper drivers?
0.55mV works best.
What about the reference voltages on the new board?
Did you adjust them?
Out of the box they are set around 0.80 this make the driver over heat and do crazy thing like you are seeing.
It starts OK but when they heat up then they act stupid.
I would start there Just adjust the X,Y and Z the Extruder should be OK since you have the K8203.
I didn’t adjust at all apart from the extruder driver. Certainly they sometimes ran OK laying down 2 skirt loops, 3 or 4 perimeters before losing the plot. Other times started misbehaving on the skirt loops. Have sent the board back to the supplier under warranty so will wait for their report.
