Hello, i am looking at replacing the USB port for my k2800 circuit, I am unsure of the type of USB, can anyone help me?
https://sg.rs-online.com/web/p/usb-connectors/1612492
Is this USB compatible with the board? If not can someone give a reccomendation?
PPAC
2
Hello !
It seems to me that on the original card it is Micro USB Type B
https://reprap.org/wiki/3drag
https://reprap.org/wiki/3Drag_controller
I had inadvertently torn off the port so I directly soldered a USB cable that I sacrificed. because the tracks were damaged to resolder a port.
You need to identify where to solder 4 wires: + 5V, GND, DATA + and DATA -. (from an old post on this forum …)
