bonsoir,
je n’arrive pas à télécharger les dossiers 5 et 14 de la notice de montage.
pour tous les autres c’est OK.
autre question , pour me motiver, quel est le temps de montage estimatif / moyen de l’imprimante ?
merci
Frederic
bonsoir,
merci
Frederic
I would estimate about 10-16 hours, depending on your skill level. Wiring will take up the largest amount of time.
The download links for chapter 5 and 14 (French) are working correctly. You will need to be more precise about why you can’t download these chapters.
thanks for first rapid reply
when i click on “TELECHARGER PDF” button on chapter 5 (same with chapter 14), download start.
a scroll bar appears with différents number each time "Chargement en cours 137,1 “or some times " Chargement en cours 76 / 941”
and nothing else. download is locked even if i wait 5 minutes.
regards
(sorry for my English)
That is a common problem with PDF’s that are being viewed inside the browser window.
Usually the trick is to download the file instead of opening it inside your browser. You can do this by right-clicking on the link, and selecting “Save target as…”. Save the file to your hard drive, and open it once download is complete.
