After 8 years i finaly took the time to upgrade my rod of the z-axe.
But i did a stupped thing, i forgot to take a picture from my EEPROM settings.
Now i upgraded my firmware and now i cannot check if the values are the same so i can see if the values are correct and i ony have to change the steps off the z-axe.
Is someone out there how can place a snapshot from the original eeprom values of the K8200?
Hello
sorry I did not keep the result of M503 ( Report Settings | Marlin Firmware ) on my k8200 and therefore I no longer have the default values. And I made other modification.
(but if I remember correctly there are only the steps / mm for the Z axis that change. You go from 2133.333 to 2560 steps / mm because the screw pitch goes from 1.5mm to 1.25mm (you have to do more of steps to go up by 1mm)
