K8200 Repetier software
Will the k8200 printer work on Windows 10 with one of the newer versions of Repetier? I can’t find any configuration/settings instructions for setting it up on any Repetier versions other than V0.84.
You may need to download the the one configured for the K8200 and get the settings from that
K8200-PLA-STANDARD_NEW.INI Slic3r configuration file for standard PLA prints. Consult the K8200 manual on how to use this file. This file is only compatible with Repetier 0.90 and Slic3r 0.9.10b.
https://www.velleman.eu/support/downloads/?code=K8200
