Hello;
I am by no means a pro with the k8200 or rapidprototyping,
yet, I look forward to some answers to these excellent questions -
I recommend taking some benchmark data or evaluating the k8200 and similar repstrap printer, at a local print club or 3D club at a tafe/uni… besides being a fun way to meet fellow enthusiast etc… it give a great tactile ‘try before you buy’.
The manual says one thing, though it will be great to hear the experienced users experiences hehehe.
the following is tentative, based on my own journal and experience; temps are a combination from the onboard thermistor, and from 3rd party lazer temperature monitoring (similar to as used in bakeries etc). Calibration check is performed at the start of each print job, at the mid point, and after the print job concludes. (some on youtube, have used a thermal camera even, to get a better average etc…)
in the stock scenario, an out of the box k8200,
average safe operating extruder temp is 200-240degree Celsius,
max possible temp, 345degrees (though, this will evaporate most filament)
the machine would melt down at 280degrees onwards…
with the stock heated bed,
max safe operating temp ~75degrees
max possible temp -125degrees celsius.
(considerably less, if you use some glass or mirrored surface instead, such as nesquick/milo tin superpolished and coat with some sealant)
50degrees is enough to ensure cohesion in most cases, or a thin patina of a glue of your choice = )
I can vouch for the k8200 being able to handle ABS - I recommend using a respirator, as ABS prolonged exposure can cause asbestosis-like symptom (similar to sawdust etc), and a well ventilated area - also, check with a landlord if you are renting etc… as some landlords dislike the smell. PLA and to a lesser extent, PETG, smell much nicer, and are less/non-toxic.
(Do not leave an operating 3D printer unattended, or operated by untrained persons or minors, unattended. = )
In theory, provided you use the correct flowrate, hot end and test… yes, it may be possible to use PETG of various diameter.
I recommend using the procedure described in the velleman k8200 manual - mark to find the extrusion rate and flowrate, and test the plastic, then do some test print (a conic segment, a sphere, some 0.1mm holes with various layer height and wall thickness). if that works, and is not so brittle, you have a viable plastic.
This said, from some horror stories at the local print club;
some people were sold ‘filament’ along with another 3D replicator machine from another website, ali-somethingorother bazaar…, which was actually non-thermoplastic whippersnippy cord - attempting to extrude that material didn’t work, and led more to ‘burning’ and inconsistent results hehehe.
I have also heard of creative individuals, attempting to use plastic fishing line, and claiming it works - this depends on the brand - it must be thermoplastic, etc… (usually of the appropriate number and type, as indicated by the little number inside the triangle, and the PDS for the plastic).
It may also produce noticeable layerlines, if you attempt to print spherical or conicsegments, as compared with a scintilated resin printer, such as Form+1… or industrial rapidprototypers like Shapeways. each type has its own advantages
Good luck, and i look forward to seeing what you can achieve, no matter what printer you opt with.
