Hi there,
while building the printer I noticed some minor mistakes in the manual. Nothing realy big but if not mentioned it cannot be corrected. The page references are for the Dutch ‘offline’-PDF manual, but also occur in the ‘online’-manual and in the English version.
P494 / 531 / 584: wiring of the X-, Y- and Z-stop connector on the mainboard side. You have to remove the middle wire (red) from the 3 wire ‘board-to-wire’ connectors. Next step is to solder the wires together: red to red; brown to brown. As the red wire has been cut off, this should be ‘red to orange’.
P472 / 499 / 572: cutting of heat shrink tubing. Text says ‘cut 2 tubes’ - picture shows 4; and the other way around…
As I said before, no big deal. Anyone with some common sense can figure this out. But better changed to avoid disturbance.
Regards and lots of ‘building fun’.
