I just finished mounting my GT2 belts and the 16 tooth pulleys.
I used parts i found on thingiverse for the bearing and modified Y motor mount.
Seems to run quite well.
The 16 tooth pulleys give better precision and torque on both axes as the pulleys are lot smaller.
The 100 steps/mm i get with those make the bed run a lot smoother.
Also the belt is way more stiff in all.
Test print is running at the moment. (makerook in ABS)
I think i will remake the X pulley holder as the part i got from thingiverse is not very stable.
I do some testing and then post some pictures of the results.
And the result :
Spiral vase, 0.2mm layers, 0.25mm nozzle, clear blue pla, print speed max 60mm/s
(i chose the smaller nozzle to make possible imperfections better visible)
