e3d-online.com/Electrical/Electr … fier-Board thats the actual amplifier board.
I have updated latest marlin firmware and fiddled about with the thermotables.h
in the latest firmware pt100 with a 1k and 4.7k pullup resistor are listed but neither of those work and the table recommended by e3d to use (20) still gives very innacurate readings
This is the thermtable for setting 20 as recommended by E3D
#if (THERMISTORHEATER_0 == 20) || (THERMISTORHEATER_1 == 20) || (THERMISTORHEATER_2 == 20) || (THERMISTORBED == 20) // PT100 with INA826 amp on Ultimaker v2.0 electronics
/* The PT100 in the Ultimaker v2.0 electronics has a high sample value for a high temperature.
This does not match the normal thermistor behaviour so we need to set the following defines */
#define HEATER_0_RAW_HI_TEMP 16383
#define HEATER_0_RAW_LO_TEMP 0
#endif
#if (THERMISTORHEATER_1 == 20)
#define HEATER_1_RAW_HI_TEMP 16383
#define HEATER_1_RAW_LO_TEMP 0
#endif
#if (THERMISTORHEATER_2 == 20)
#define HEATER_2_RAW_HI_TEMP 16383
#define HEATER_2_RAW_LO_TEMP 0
#endif
#if (THERMISTORHEATER_3 == 20)
#define HEATER_3_RAW_HI_TEMP 16383
#define HEATER_3_RAW_LO_TEMP 0
#endif
#if (THERMISTORBED == 20)
#define HEATER_BED_RAW_HI_TEMP 16383
#define HEATER_BED_RAW_LO_TEMP 0
#endif
const short temptable_20[][2] PROGMEM = {
{ 0 * OVERSAMPLENR , 0 },
{ 227 * OVERSAMPLENR , 1 },
{ 236 * OVERSAMPLENR , 10 },
{ 245 * OVERSAMPLENR , 20 },
{ 253 * OVERSAMPLENR , 30 },
{ 262 * OVERSAMPLENR , 40 },
{ 270 * OVERSAMPLENR , 50 },
{ 279 * OVERSAMPLENR , 60 },
{ 287 * OVERSAMPLENR , 70 },
{ 295 * OVERSAMPLENR , 80 },
{ 304 * OVERSAMPLENR , 90 },
{ 312 * OVERSAMPLENR , 100 },
{ 320 * OVERSAMPLENR , 110 },
{ 329 * OVERSAMPLENR , 120 },
{ 337 * OVERSAMPLENR , 130 },
{ 345 * OVERSAMPLENR , 140 },
{ 353 * OVERSAMPLENR , 150 },
{ 361 * OVERSAMPLENR , 160 },
{ 369 * OVERSAMPLENR , 170 },
{ 377 * OVERSAMPLENR , 180 },
{ 385 * OVERSAMPLENR , 190 },
{ 393 * OVERSAMPLENR , 200 },
{ 401 * OVERSAMPLENR , 210 },
{ 409 * OVERSAMPLENR , 220 },
{ 417 * OVERSAMPLENR , 230 },
{ 424 * OVERSAMPLENR , 240 },
{ 432 * OVERSAMPLENR , 250 },
{ 440 * OVERSAMPLENR , 260 },
{ 447 * OVERSAMPLENR , 270 },
{ 455 * OVERSAMPLENR , 280 },
{ 463 * OVERSAMPLENR , 290 },
{ 470 * OVERSAMPLENR , 300 },
{ 478 * OVERSAMPLENR , 310 },
{ 485 * OVERSAMPLENR , 320 },
{ 493 * OVERSAMPLENR , 330 },
{ 500 * OVERSAMPLENR , 340 },
{ 507 * OVERSAMPLENR , 350 },
{ 515 * OVERSAMPLENR , 360 },
{ 522 * OVERSAMPLENR , 370 },
{ 529 * OVERSAMPLENR , 380 },
{ 537 * OVERSAMPLENR , 390 },
{ 544 * OVERSAMPLENR , 400 },
{ 614 * OVERSAMPLENR , 500 },
{ 681 * OVERSAMPLENR , 600 },
{ 744 * OVERSAMPLENR , 700 },
{ 805 * OVERSAMPLENR , 800 },
{ 862 * OVERSAMPLENR , 900 },
{ 917 * OVERSAMPLENR , 1000 },
{ 968 * OVERSAMPLENR , 1100 }
#endif
but this gives my initial idle temperature of around 38/39C when my infrared thermometer reads approx 21-22C
I followed the advice from another thread on this forum for using the amplifier board with the k8200 control board. I have the ground and signal (from therm) wired to ground and signal on the amp board, and i have installed a new pin socket from a 5v pad under one of the stepper drivers on the control board and have this wired to the 5v on the amp board. I have measured the 5v and it reads a steady 4.98v.
Ill be honest, I literally have no clue as to how I would do a custom temperature table and id probably never trust it. I just dont understand how others have done this and it apparently works, but it just doesnt match up with mine. viewtopic.php?f=53&t=13596
