K8200 Driver problems Mac
Having problem installing the driver on my mac, running OS X 10.11.5
When i do the instal program from FTDI I use the 2.3 version for Mac OS X 10.9 and above. After installation I cannot get the driver to work. Does anybody know what I’m doing wrong? Because I cannot get a connection in Repetier, now when I try to connect it only says Virtual Printer of Bluetooth incoming port. And when I click connect it says:
FIRMWARE_NAME:RepetierVirtualPrinter FIRMWARE_URL:https:/github.com/repetier?Repetier-Firmware/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:Mendel EXTRUDER_COUNT:1 REPETIER_PROTOCOL:1
So I think my driver isn’t set up the way it should, because I cannot get any connection with the Velleman K8200.
Mike
Just to see if the printer is working do you or maybe a friend have a Windows machine to test it on?
Unfortunately I do not speak Mac.
Think I solved my problem, although I have the latest version of IOS. If you use the 32bit driver from the older version then it works!
