K8200 axe X
good morning I warn you in advance, I am French
(I neither know anything 3d printer)
I followed the tutorial(k8200.eu/manual/building)
I post on the forum my problem with my 3d k8200 printer
the printer works fine
Everything works fine except -X axis
(I control the printer with the K8200 Program Repetier-Host)
+Y ok
-Y ok
+Z ok
-Z ok
+X ok
-X not moving
I do not understand why it does not work
the cable are mid
the map and origin
the driver are .425V
for further questions I am available
This is an open wire fir the X axis end stop (micro switch)
If the axis will move away from the end stop but not to it this indicates there is a broken wire or solder joint.
Also set the driver voltage to 0.55
This works better
Hello Wrong Way
wire are welded is the tansion is 0.55 toujour is nothing to move -X
I invert the Y motor driver with the X motor driver toujour but nothing moves except + X
cordially good night
Bonjour, Multimix.
Wrong way a raison ce doit être un problème de end-stop. Va voir dans le [color=#404000]Wiki [/color](déso pas encore traduit).
Edit : le Wiki est traduit en français maintenant.
I really need to learn French.
Bonjour raby et Wrong Way
non sa fonctionne toujours pas
je vien de contacter velleman
il mon dit (vu que vous avez pas acheter l’imprimante chez nous, nous ne pouvons vous donner des conseille).
je pense donc en racheter une autre autre que velleman
cordialement MultiMix
Now:
x axis connector -> x axis pins on board
y axis connector -> y axis pins on board
X+ not working, X- ok, Y+ ok, Y- ok
Try this:
x axis connector -> y axis pins on board
y axis connector -> x axis pins on board
expected result:
X+ ok, X- ok, Y+ not working, Y- ok
X axis stop switch terminals:
Left -> wire, middle -> no wire, right -> wire
Hope that translates and helps.
[quote=“MultiMix”]vu que vous avez pas acheter l’imprimante chez nous[/quote]Ils ne vendent pas eux-même donc je ne saisis pas cette réponse. Tu l’as acheté où?
je les acheter chez selectronic.fr/velleman-impr … k8200.html
[quote=“MultiMix”]je les acheter chez selectronic.fr/velleman-impr … k8200.html[/quote]Normalement il n’y a pas de problème mais les questions techniques sont à poser dans le forum. Il ne répondent aux mails que pour l’échange de pièces défectueuses.
As tu essayé ce que Barnabybear suggère? Un axe qui ne fait que s’éloigner du end-stop suggère un problème à ce niveau. Il n’y a pas que les soudures qui peuvent être en cause. J’ai eu le cas avec un contact tordu dans la fiche --> ne faisait pas contact avec la carte contrôleur.
Pour qu’on puisse t’aider, il faut énumérer ce que tu as testé pour qu’on sache s’il reste des options.
Bonjour Pour le moment j’ai donner imprimante a mon prof qui a la même
il me dira d’ici environ 2 jour se qui se passe
Bonjour
mon prof ma dit que sais un problème de carte de contrôle
cordialement
[quote=“MultiMix”]
mon prof ma dit que sais un problème de carte de contrôle[/quote]Si c’est le cas il faut renvoyer la carte au SAV. Envoye un mail expliquant ton problème à supportatvellemandotcom et avec un lien vers ce post.
Pas de problème, je fais sa tout de suite merci de votre aide
Raby,
Just wondering did he get the problem fixed?
If so what was it?
[quote=“Wrong Way”]Just wondering did he get the problem fixed?[/quote]His teacher who owns the same printer told him it’s a faulty controller board so he sent it back for inspection. No return till now.
Thank you.
