Thank you so much for your answer. That helps me aot and it works out.
now the 3d printer is ready to print. but still, i have a problem with the slic3r. I have downloaded the K8200 PLA standard download of zipped file and I just extrat the zipped files.
- I clicked the slicer button and then click active, and then when i clicked the configure button. I have got this message.
11:16:06.360 : Unknown option solid_infill_extruder
11:16:06.360 : Unknown option infill_first
11:16:06.360 : Unknown option solid_infill_extrusion_width
11:16:06.360 : Unknown option infill_only_where_needed
11:16:06.360 : Unknown option max_volumetric_speed
11:16:06.360 : Unknown option external_perimeters_first
11:16:06.360 : Unknown option support_material_interface_extruder
11:16:06.360 : Unknown option support_material_interface_spacing
11:16:06.360 : Unknown option support_material_enforce_layers
11:16:06.360 : Unknown option top_infill_extrusion_width
11:16:06.360 : Unknown option standby_temperature_delta
11:16:06.360 : Unknown option bridge_acceleration
11:16:06.360 : Unknown option ooze_prevention
11:16:06.360 : Unknown option avoid_crossing_perimeters
11:16:06.360 : Unknown option external_fill_pattern
11:16:06.360 : Unknown option max_print_speed
11:16:06.361 : Unknown option dont_support_bridges
11:16:06.361 : Unknown option support_material_interface_layers
11:16:06.361 : Unknown option interface_shells
11:16:06.361 : Unknown option thin_walls
11:16:06.361 : Unknown option spiral_vase
11:16:06.361 : Unknown option support_material_interface_speed
11:16:06.361 : Unknown option first_layer_acceleration
11:16:06.361 : Unknown option resolution
11:16:06.361 : Unknown option overhangs
11:16:06.361 : Unknown option seam_position
11:16:06.361 : Unknown option xy_size_compensation
11:16:06.361 : Unknown option infill_overlap
11:16:06.361 : Unknown option raft_layers
11:16:06.361 : Unknown option external_perimeter_extrusion_width
11:16:06.361 : Unknown option support_material_contact_distance
11:16:06.459 : unable to resolve overloaded method for Wx::ComboBox::SetSelection at C:/PROGRA~1/Repetier-Host/Slic3r/lib/std/Slic3r/GUI/Tab.pm line 824
but the manual said that it will come up another small slic3r window. what can i do? what step should i follow? where should i extract the K8200 PLA standard download of zipped file? what is the solution?
Thanks in advance.
Report this post
