I almost done my k8118, but I don’t know how to mount microphone (jumper in fact).
Photos in manual doesn’t show jumper from solder side before soldering.
Jumper should start first hole go to solder side and then go thru next hole or go to the edge and go thru hole from mount side?
Yes, the wires should go to the edge and go thru hole from mount side.
Then you can easily solder the microphone to the wires.
Like in first case or second?
The first case may be easier. Both are OK.
I can’t instal it. It is too small. I’ve instal so many elements and in the end i cann’t instal microphones. Even if I try to solder it with straight wire not on PCB it is to hard. I’m so disapointment.
