The product info states the dimensions:
LCD :128 x 64mm / 5 x 2.5" (46 x 24mm / 1.8 x 0.95")
frontpanel: 98 x 51mm / 3.8 x 2"
It seems the LCD is bigger than the frontpanel?
What are the visible dimensions of the LCD screen actually?
Paul
Paul
Frontpanel cut-out for LCD (= visible part of LCD): 53x27mm
The active area with the 128 x 64 pixels has the size of 46 mm x 23 mm.
The frontpanel cut-out has the size of 53 mm x 27 mm, what is 7 mm wider and 4 mm higher than the displaying area.
(The docu is wrong: 128 x 64mm must read 128 x 64 pixels, 46 x 24 mm must read 46 mm x 23 mm.)
@Bernhard: Yes, I see.
We will update the manual.
Thanks for the feedback.
