Giellio
September 22, 2011, 1:30pm
1
Dots appear on wrong places .
I found one topic where someone solved the problem with 100NF across the GND and VCC of the PIC.
But for me it doesn’t help .
I wonder if Velleman has a solutuion for this.
I already bought 3 of these kits and they al have the same problem.
I have replaced the pic’s aswell , still the same!
Please Velleman have a look at this problem cause i know i am not the only one with this problem.
If somebody has more solution’s please let us know.
Thank you in advance…
BR Michiel
VEL417
September 22, 2011, 1:41pm
2
Between which points and how did you connect the cap?
Giellio
September 22, 2011, 2:35pm
3
As close as possible to the VCC and GND of the PIC .
I soldered the capicitor on the backside of the PCB.
Unfortunally it didn’t solved the problem
VEL417
September 22, 2011, 3:04pm
4
What power supply are you using to power this kit?
Giellio
September 22, 2011, 3:42pm
5
Unfortunally it didn’t solved the problem [/quote]
Is there a better way to do it??
Giellio
September 22, 2011, 3:47pm
6
A switching one from a external hard disk 12v 1A
Do you think a power suply like this is not stabil anough ??
( could be possible)
I wil try again on a 9v batt.
i will come back on this BR Giellio
VEL417
September 23, 2011, 6:36am
7
Could be interesting to check if the problem is PSU related.
