K8097 use over current as a limit switch
Is there a possibility how i work with an overcurrent as an limit switch. Because i don´t want to buy an extra limit switch. I read that the K8097 has an over current protection sensing.
Hope you can help me.
Not sure the protection circuitry of the drivers actually has an output which can be read.
You might want to check the datasheet of the driver IC’s.
