I need to use the K8096 from within a C# application.
I’ve written the following code based on the MotorLibNET HTML manual
I have the following class to import the MotorLibNET.dll
namespace Velleman.Kits
public static class SMC
[DllImport(“MotorLibNET.dll”)]
public static extern bool Connect(string port, int motors);
On the main screen I have a Connect-button with following code
private void button_Connect_Click(object sender, EventArgs e)
SMC.Connect(comboBox_Usb_Port.Text, 0);
When I build the code there are no errors
When I press the connect-button the following error message is displayed
Unable to find an entry point named “Connect” in DLL MotorLibNET.dll
What is going wrong?
What is the solution?
