K8096-GetMoving(0)
I am working with c# to adress a K8096 board.
I can connect the card, i can move my mots1 motor to the left or to the rigth.
but SMC.GetMoving(0) always return false so i am not able to know if my motor have finished to move.
Does anyone managed to use this instruction?
thank for your answers
Ok now it is working,
using a timer and two while loops : the first to wait the motor start and the second during the movement of the motor
namespace WindowsFormsApplication5
public partial class Form1 : Form
static public string port = “COM10”;
static public bool tour;
public Form1()
InitializeComponent(); tour = false;
    private void button1_Click(object sender, EventArgs e)
        int vitesse = System.Convert.ToInt16(textBox1.Text);
        int sens=-1;
        if (radio1.Checked) { sens = 1; }
        else { sens = 0; }
        SMC.Connect(port, 1);
        bool connec = SMC.Connected(); SMC.SetDemo(true);
        if (connec)
            SMC.SetTorque(0, true);
            SMC.Move(0, 2048, sens, vitesse);
            while (!tour)
                Application.DoEvents(); led1.Value = true;
            while (tour)
                Application.DoEvents(); led1.Value = false;
            led1.Value = true;
            SMC.Disconnect();
        else { MessageBox.Show ("non connecté"); }
    private void timer1_Tick(object sender, EventArgs e)
       tour = SMC.GetMoving(0);
[quote=“jamon”]
}[/quote]
When do you start the timer (timer1.enabled) and what is the timer1.Interval?
ps. And yes I’ve managed your function with the K8097 board also using a timer
Greetz Deekay
HI,
Can someone show me how to code C# to access the SMC-functions?
I’m using Visuals Studio 2016 but nit able to access the SMC :frowning:
