K8095
When i power up the MP3 player it stuck in boot screen ; VELLEMAN MP3 PLAYER, when I press the play button the unit works fine.
Also I cannot store any settings on the player, probably it is software related.
The software version in the player is REV 1.10.10.
Kind regards,
JC.
[quote]When i power up the MP3 player it stuck in boot screen ; VELLEMAN MP3 PLAYER, when I press the play button the unit works fine.[/quote]This is normal operation. You have to press the play button to start the player.
You can select the play mode “Startup play on”: When the MP3 unit is powered off it will start automatically to play when powered on.
[quote]Also I cannot store any settings on the player, probably it is software related.[/quote]You must place the player shortly in sleep mode to save the settings.
Long press the Play button to place the player in sleep mode.
