I want to create a MP3 Juckbox with a Velleman 8095 MP3 Player.
I bought 2 Vellaman 8095 MP3 Player Module. Both of them show the same fault, if you turn it on.
As soon as you plug the MP3 decoder in to the board (withaout any voltage on the board), the resistor value between the VDD pin on the J6 Jumpers and GND is 23 Ohms. If you unplug the MP3 Decoder, there is a 1,7kOhms resistor value.
If you measure directly on the decoder board between the pins VDD + 3.3V and ground, there is only a resistance of 20 Ohms.
Can anyone tell me what I’m doing wrong ? Or what else I can do?
