The K8095 runs. Have an LCD display EA W162B-N3LW, that works. The music is playing. I can fast forward, rewind. However, no sound comes out. No sound on the headphones. No sound on RCA. No sound on the speaker pins.
Can anybody help me further?
Please check the pins 7 and 8 of IC2 are connected to +12V and pins 2 and 5 are connected to ‘ground’.
Also check the right polarity of IC2.
Hi Vell255
Thank you for your quick response. Pin 7 + 8 have + 12V and pin 2 + 5 are on ground. Other idea?
sincerely
Fredy
Have you tried with other MP3 files (or maybe other SD card)?
Check all the pins of IC3 are properly in the socket - no bent pins etc.
You can return the K8095 for inspection/repair to your local Velleman dealer or direct to:
Velleman Projects Tech. Dept.
Legen Heirweg 33
9890 Gavere
Belgium
Please make sure to include the fault description and return address.
Hello Vell255
Oh how embarrassing!! I had a defective copy of mp3 Tina Turner. On the LCD screen I saw the title and the time. However, on the mp3 file was no sound. the K8095 is now working with an intact mp3 file flawlessly !!!
Thank you and Happy New Year!!
Fredy
OK - No problem.
I’m glad to see your K8095 is now working.
