Got my MP3 player assembled, and it works beautifully, apart from the LCD screen. The screen lights up when power is on, but there is no display. When I do get a display, it’s all on one line and garbage, like “oo_-ie!/?>//////////////?” that just cycles across and then repeats. I’ve had it come on once or twice and display “Velleman MP3 Player” and got it to display the artist/song and the EQ setting, but that was twice out of about 50 boot cycles. More recently, it’s got no display at all. Not even black boxes on line 1 with the potentiometer set to max. Just backlighting.
I’ve checked resistance across pins 4 and 5 of J8, and they are not shorted. Visually double checked all the solder points around the PIC, the display socket, and ensured all connections are good on the display socket and board, also reseated multiple times. My friend has the same kit, and I’ve also swapped PIC’s just to ensure that it wasn’t the issue. What else should I check, or should I write it off as a bad LCD?
