HI EVERYONE!
HOW COULD THE LCD BE MOUNTED ON THE K8095 PCB?
THE RECOMMENDED BY VELLEMAN LCD, PC1602WRS-KWA-E PDF, HAS 16 PINS BUT THE PCB CAN ONLY ACCEPT 12.
BEST REGARDS,
ENEARCHO
The K8095 is supplied with a “conversion” connector PCB.
The LCD is controlled in “nibble” mode, so 4 connections are not nessesary.
Please note that the convertor pcb which is supplied with the kit is only for mounting the sd card socket vertically.
Kind regards,
ENEARCHO
That’s NOT true !
There is a PCB included with the display connector, I think you did’nt made this kit already ?
Hi!
Thanks a lot for your respond.
To be honest i have not assembled the kit yet so obviously i had not opened the plastic bag which includes the MP3 module.
I have just opened that and i can confirm that there is a PCB attached to the MP3 module which can be used for connecting the VELLEMAN LCD, PC1602WRS-KWA-E PDF, to the main PCB.
I would like to thank you, once again, for your assistance.
Kind regards
enearcho, are you still interested in a 2569 Morse decoder? I just got one today I’d be glad to send you.
