Hello, is it possible to turn off or dim the LCD backlight of the K8095 ?
Another question: Is it possible to put the mp3 module on “stop” ?
If you push SW1, LD1 continu lights and the module is playing.
If you push again on SW1, LD1 flashes and the module is on pause.
I want the module to stop, not on pause or sleep.
Long button press SW1 puts the module in sleep mode, that’s not what I ment.
Is is possible to turn off the backlight LCD when the module is playing?
I just want to read the LCD without the backlight or dimmed backlight.
Maybe change a component on the module ?
