Hello I am not a programmer but the k8090 fascinates me and I would love to know it.
Thanks to your examples I managed to realize a perte of page that interests me.
SORRY MY ENGLISH:
Would like to know what are sub to be written in visual basic so you know if the inputs (manual operation) are on-off thanks
hi, the verision is Microsoft Visual Basic 2008 Express Edition. I need to know how i can read the output from the K8090 end activate e Led on my sw to know if the input is on…
Thanx for yuor attention.
you’ve downloaded the software for the k8090 but I wanted to create a program for my esiggenze. I can control the relays man I do not know the sub to recognize inputs or manual oporezione buttons. can you help me thank you pel patience.
an example to explain my problem: This sub active relay through bottone3;
Private Sub Button3_Click (ByVal sender As system.object, ByVal e As system.EventArgs) Handles Button3.click
’ Switch relays on (&h16)
K8090. ToggleRelay ()
[color=#0000FF]End Sub [/color]
qualèla sub to receive inputs manual operation? Thanks again
Take a look at the second sample provided in the software package. It declares a K8090_CommandReceived event like this:
Private Sub K8090_CommandReceived(ByVal o As System.Object, _
ByVal args As Velleman.Kits.CommandEventArgs) Handles K8090.CommandReceived
' Add the event to our list
PacketList.Items.Add("Received event " + args.cmd.ToString())
End Sub
Change it to this:
If args.cmd = Velleman.Kits.K8090Command.ButtonStatus Then
' We can examine args.param1 to know which buttons have
' been pressed. Each button is represented by a bit in args.param1,
' so we'll need to check which bits are set.
' args.param1
' | 8 | 7 | 6 | 5 | 4 | 3 | 2 | 1 |
' | 0 | 1 | 0 | 0 | 0 | 0 | 0 | 0 |
' button 7 was pressed
Dim i As Integer
For i = 0 To 7
If args.param1 And (1 << i) Then
PacketList.Items.Add("button " + (i + 1).ToString() + " pressed")
End If
Next
End If
End Sub
This is also explained in the Developer’s Guide that comes with the examples.
Thank you for the examples, and work great. I’ve also extended the example at all entrances. saw your collaboration I would improve my program displaying the input as a symbol example (checkbox) that indicates if the entrance and to 0 or 1 thank you all symbol. (as happens in the demo K8090) THANK YOU FOR COLLABORATION
Hello. I would like for the button 1 (input) at level 1, the color of label1 is red and programmatic or label1 is green. for the button 2 (input) at level 1, the color of label2 is red and programmatic or label is green. still thank you for your cooperation and I apologize for English. I await your reply.
Create three labels named lblButton1, lblButton2 and lblButton3
// Buttons = &H1, &H2, &H4, &H8, &H10, &H20, &H40, &H80
// args.mask = current state of each button
// args.param1 = button presses
// args.param2 = button releases
If (args.mask And 1) = &H1 Then
lblButton1.ForeColor = System.Drawing.Color.Green
Else
lblButton1.ForeColor = System.Drawing.Color.Red
End If
End If
Even better would be to use arrays and a loop to iterate over each button and show its status.
the example you gave aquisisce bit 1 and bits 0 inputs. but if bit of ’ input 1 and only 1 bit of eil ’ input 2 goes to 1 reporting (label) changes of State I am servirebero inputs between them independent. thank you again for your patience
I remember that I’m not a programmer and I couldn’t take the hint:
“Even better would be to use arrays and a loop to iterate over each button and show its status”.
If possible let me through an example.
I’ve read and reread this about four times and I just can’t figure out what you’re trying to say… i’m sorry
Remember that each bit represents a button. Also, use any parameter that suits your needs: args.mask bit 0-7: State of button 1…8. If the bit is set, the corresponding button is pressed. args.param1 bit 0-7: Button 1…8 has been pressed args.param2 bit 0-7: Button 1…8 has been released
You probably need args.mask since you want the current state of everything. You can find all this information in the Protocol Guide and the K8090 Visual Basic.NET Developer’s Guide.
oooooooookkkkkk thanks the example works fine. I need a help to a relay timed … I would like to know the sub to temporizar the status relay 1 for a time by pressing a button. Thanks a lot for your patience.
' First set all buttons to timed mode (Page 6 of the Protocol Guide)
SendCommand(K8090Command.SetButtonMode, &H00, &H00, &HFF);
' Set the timer delay to 3 seconds (Page 7 of the Protocol Guide)
SendCommand(K8090Command.SetRelayTimerDelay, &HFF, 0, 3);
Once you’ve sent this, pressing a button should activate the corresponding relay for 3 seconds
