My new k8090 works fine, but some times while I’m connected it goes bloked without a reason. In order to reset the problem I must unplug and plug the usb cable then reconnect again the k8090 by software.
Thanks and Huppy Easter
Federico
Federico
When does this happen? Can you reproduce this behavior by executing certain actions? Do you still see the USB data led blinking?
It happens when I push several (ten to fiveteen) times one of the buttons, it does not matter wath it is.
Wen the problem is in the USB data led does not blink any longher.
This problem not always happen ! but as I must use this card with a remote connection I have to be sure that is working well.
Thank you
Federico
