These days I bouhgt and built the second K8090 Relayboard.
The first one is working perfect.
The second gives me a questions:
Below the red controllight of Relay 1 - where i can see if it is on or off - is a red arrow where i dont know why…
see screenshot.
This button 1 is default ON when i start the programm.
How i can do or undo this???
And second question: is it possible to change the red controllight into green if it is on?
Now the different to see is very difficult for me under light conditions…
Hello !
I dont have a K8090.
Sorry unless you find the source code it seems complicated to change the colors. (maybe a hacker could edit in hexadecimal and find in the binary where the image and the color are coded)
For the relay always ON I do not know … may be the programming on the card (a jumper? a defaut fonction …) Or an assembly fault.
Thanks for help.
I will search this file and try.
On the board itself is only one jumper to select externe power or not…
So i hope that somebody can help me who has one K8090.
