Hello, I have a K8089 57mm clock kit with a damaged pcb, is there any chance I could source a replacement pcb? What is the recommended power supply for this item also? Where can I find replacement components if i need them? -
thank you
I tried to follow the schematic but found it confusing, any support would be helpful.
What is the recommended power supply for this? Thanks
Dear VElectric,
The specs in manual says that You need a 12VAC power supply min 500mA.
So the recommended power supply is these 12VAC / 8VA : TR-G3/8
For replacement PCB and components, You can Contact Your local dealer / shop where you bought this kit.
Best Regads,
Velleman Support
