K8086
I’ve recently assembled a K8056,
when I use the test switch then all the relay works.
But when i connect it to the pc, I can’t get it working?
When i use the test software and push “change addr.”
then relay nr.5 turns on
and “Emergency STOP” Turns it off
All other Buttons dosen’t work
Led10 Flash every time i push a button in the software
Anyone know how to fix this?
Card seems to work OK, just a matter of selecting correct address.
Press ‘show address’, unit will show its address (see manual).
[quote=“VEL417”]Card seems to work OK, just a matter of selecting correct address.
Press ‘show address’, unit will show its address (see manual).[/quote]
:smiley: Thank you !!
