I’d like to know if K8086 kit works with french Public Switched Telephone Network (PSTN) ?
And how the kit must be connected to the phone line: simply plugged in “parallel mode” between pins 1 & 3 of the connector (2 & 3 in assembly manual but in France only 1 & 3 are used) ?
I need help here!!!Just want to understand how this ring detector works with the relay o/p…
I had assemble and input the ringing signal, when signal comes in o/p relay was able to activate from normally close to normally open however when ring signal stops( after palcing handset back), the relay failed to retract back to the original position, Can somone advise what is the problem here??
Managed to isolate the fault to be due to the wrong orientation of the transistor. Now the relay able to retract back however notice that it takes abt 2-3 seconds after i picked up the handset.
