with the K8084 pre amp can I bridge the input or output sockets to run in mono mode?
Thanks,
Chris.
No, this is not possible.
You can simply use one channel instead.
OK thanks for your reply.
Could I then just plug a guitar into both input sockets at the same time?
The reason I ask is that I am running two k8060 amps and would like to fed both amps at the same time.
Thanks,
Chris.
