K8077 Bass reflex
Hi, THere’s something i don’t understand with the bass reflex pipe. You have the pipe and a pipe which slides over it. Now if you put the bass reflex in, this other pipe is on too, but if you then move the whole subwoofer there’s a chance that the slided over pipe will fall off. Do i need to find a good bass first and then put it together with silicone?Or something else?
If you drill a small hole at the end of the outer tube, you can adjust the length with a ridgid piece of wire, from the outside, while listening. Next, if you have found the ideal length, you can open the enclosure (remove speaker) and fix the tube with some glue
