K8076: OSSCAL value
I was wondering if there was any way to change the OSSCAL byte value with PicProg2006 and a K8076 programmer. I tried setting the OSSCAL byte in the file, but it seems to ignore that byte (doesn’t even show up in code view when loading the file).
Hope anyone knows of a fix to this.
Thanks in advance
No, you can’t change this value.
It’s a read-only byte.
PicProg2006 somehow overwrites the standard value with the one from the file though. In IC-Prog for example, there’s a notification, asking you if you want to overwrite the default value with the one from the file, where you can click yes or no. Maybe this would be a good feature for PicProg2006 as well.
