Got my K8076`1 and assembled it. In the paper documents (booklet) that was in the case, rs232 cable connections are defined as 5-5, 4-4, 3-3, 9-9, 8-8, 7-7, and i was happy because i could use same cable as for my K8048 experiment board, but in the help file (i installed software in K8076 subfolder in installation disc - PicProg2006) i see all the connections same, AND under the drawings stays - “* PIN 9 is not connected in K8076”.
So, the question is - is pin 9 connection needed for K8076?
Regardless of the answer, i think it should be corrected, so it does not come to some further misunderstandings.
Greetings,
Ako
