K8067
In the datasheet for the K8067 the accuracy says to be “2° full range” what does it mean? how wrong could the sensor tell the temperature, ±2°C?
And how long could the wires from a K8055 USB board be to the K8067 temperature sensor whitoute problems?
Over its complete range, it can be 2° off. If you use a smaller part of the range, accuracy will be better. As the unit is equipped with a current loop, a couple of tens of meters of wire should not be a problem.
How can i change the range i my VB program to gett better accuracy?
Now it look like this
degrees1 = CStr((101 * data1 / 256) - 23)
How will it look if i want to messure between +10 - +40 C to get better accurary?
So 20 meters wire between the K8055 and the temperature sensor are no problem, does it have to be shielded wire?
This accuracy has nothing to do with your VB software, it is a property of the K8067 hardware. As it is a current loop, you do not need to use shielded wire.
