Hi, I recently got a K8067 thermometer kit, but it doesn’t seem to be working. I only get around 130-150mV from the output. I’ve connected the resistors to ground in parallel as it says in the kit manual (I’m using 4 x 1k). The other thing I noticed is that R11 is getting hot.
I’ve checked for shorts, but I can’t see anything.
If R11 gets hot, most likely you have inverted ZD1 or there is another assembly problem.
Make sure the IC is inserted the correct way.
