Hello to everyone.
I need some technical advice and I hope someone can help.
I have just purchased a K8066 3W mono amplifier and I read on the suppliers website (Maplin UK) that it will accept a wide range of sound applications.
I want it to amplify the signal from my guitar effects pedal so that it will drive headphones for quiet personal use therefore not requiring a speaker to be connected.
Is it possible to wire the K8066 to the existing guitar effects pedal output and use it as a headphone jack socket (mono) without damaging the headphones or will it need it’s own dedicated jack socket?
Also, if the K8066 needs its own headphone socket, will the circuit get damaged if no headphone it inserted when I play the effects pedal from the normal output and into a guitar amp as the K8066 wont have a speaker connected?
Any help or information will be gratefully received.
Many thanks and best regards.
Haydn.
