It seems that when I have a light connected to the K8064 kit and when I switch off and back on this light the dimmer stops working. It becomes impossible to control the light using the dc voltage. Only after I also reconnect and connect the power to the K8064 circuit it starts working correctly again.
Is this behaviour intended? Can I do something about it (except not manually switching the connected light ) Thanks!
This is normal for this module. If you disconnect (switch off with a switch) the lamp, the controller will โseeโ a problem with the load and goโs into an alarm mode. (red led will flash?).
Thanks for your reply! Okay, at least I know itโs not a mistake I made
Do you have recommendations to work around this behaviour? For example detecting when the disconnect takes place and then reseting the velleman module?
