I have assembled and tested the K8064 kit and it worked 1st time!
Question;
When I run the dimmer to lower settings it tends to make a noise?
It goes away from about 60% onwards.
I noticed that the Inductor windings were a bit loose,
and it appears to be little unstable in fitting
Can these be silicone’d to get rid of the noise and increase the stability?
can I use a digital PWM waveform instead of 0 - 5 volts analogue?
thank you.
ps. I am impressed with the sequence of construction!
