Hi, i interfaced your K8063 single module to my PICAXE directly to pin 4 without using onboard
RS232 to TTL K8063 transistor adapter.
PROBLEM: K8063 is NOT responding at serial command, its test at power on is OK.
my code is basic from AXE; i.e. serout 0,N2400(13)
pause 150 ;mSec
serout 0,N2400(13)
pause 150 ;mSec
serout 0,N2400(1)
pause 150 ;mSec
serout 0,N2400(65)
pause 150 ;mSec
serout 0,N2400(48)
pause 150 ;mSec
serout 0,N2400(129)
i’ve tryed invert bit solution but without result
Hardware is verified by oscilloscope and runs properly at pin 4
Have you a suggestion about this.
I have a BS homework board (BS2)
I have a 4 module K8063 with a male DB9 connector
pin 2 (Rx) on the DB9 is connected to pin 0 on the Stamp
pin 5 (GND) is connected to GND on the Stamp
baudmode is 2400/8/N/1 inverted
the code attached scrolls through segments on each of the 4 modules
’ {$STAMP BS2}
’ {$PBASIC 2.5}
vell VAR Byte(10)
' THIS PROGRAMME SCROLLS THROUGH ALL SEGMENTS ON ALL 4 ADDRESSES
'UNTIL ALL FOUR SHOW 8.
x VAR Byte
y VAR Byte
z VAR Byte
FOR x = 1 TO 255 'all segments
FOR z = 1 TO 4 ' all 4 addresses
y= 256-(13+z+66+x)
