Hi all
I’ve just bought a K8062 USB to DMX convertor and just can’t get it to work after assembly
When I power it up in test mode, I get a power light and the DMX signal light flashes twice then stops. Pressing the test button again starts the DMX signal LED flashing. The flashes get longer the more the test button is pressed.
All seems ok so far.
But it just won’t control any fixtures at all
I’ve measured the voltage at the output from the board and just get a constant voltage between all pins. I was expecting a variable signal. Is this correct?
Voltage results are as follows (the constant voltage changes with the number of test button presses) :-
No of presses : pins 1 and 2 : pins 1 and 3
0 : 3.55 : 1.34
10 : 2.93 : 1.97
50 : 2.62 : 2.29
100 : 2.62 : 2.29
Everything seems to be in the right place as far as I can tell.
Does anyone have any ideas?
Thanks in advance
Andy
