Hey.
I have a problem, i cant install UBS-driver to my K8061
i am using win 10, can some one help me … plz
Hey.
To install the driver you have to disable the driver signature enforcement.
Please use the latest driver “K8061 driver update v4.0.0.0”, it is available here: vellemanusa.com/support/down … 8061&type=
Here you’ll find the instructions how to disable driver signature enforcement in Windows 10:
http://www.top-password.com/blog/how-to-disable-driver-signature-enforcement-in-windows-10-8-7/
http://www.howtogeek.com/167723/how-to-disable-driver-signature-verification-on-64-bit-windows-8.1-so-that-you-can-install-unsigned-drivers/
Did everything described after restart unsigned driver not recognized by system 8
the link saysy after new start driver install but how we put the driver program folder and WOW64 folder system sayy driver not installed
urgently need advice looking since month how hardware work with no success up to now
have a nice day
You can try if uninstall and then reinstall the driver helps to solve the problem.
What do you mean with uninstall and reinstallthe driver
copied the driver to the folder and nothing else
used a driver which is 4 years old does the actual contain system specific data
could you send us the actual driver have problems with unzip
hope advice
tried bcdedit with no sucess system saysy cant be changed
possibility needed that would start the system 8 steadily with unsigned driver
advice was to start the system temporarily with unsigned driver allowed need a system that steadily rogniz the driver
thank for advice nice day
In 64-bit version of Windows 8 you have to disable the driver signature enforcement in order to install the driver.
For more details how to disable the driver signature enforcement please see:
answers.microsoft.com/en-us/wind … a83ca6d852
Here are instructions how to disable the Driver Signature Enforcement:
learn.sparkfun.com/tutorials/di … -windows-8
Please use the latest driver “K8061 driver update v4.0.0.0” available here: velleman.eu/support/download … 8061&type=
For more info please see also these threads:
viewtopic.php?f=3&t=10491
viewtopic.php?f=3&t=3092
tried new start with unsigned drivers allowed
hardware is not recognized
did that two times with a driver 4 yearsold and with a new one downloaded
couldnt use original driver hope that the one used should be all right
didnt found a
would be great if the actual dll could directly downloaded from your adress
thank
Have you used the new K8061.DLL available in the subfolder \K8061_DLL_v4.0.0.0 of the downloaded package"K8061 driver update v4.0.0.0" available here: velleman.eu/support/download … 8061&type=
With the new driver you have to use this new DLL version 4.0.0.0.
When downloaded and extracted the package, install the driver from the subfolder \K8061Driver_v1.0.0.2
In the device manager check the driver v1.0.0.2 is installed.
To test the K8061 board, run the K8061_Demo.exe in the subfolder \K8061Demo.
Here step-by-step instructions how to install the new driver and how to test the K8061 board:
Why should a driver install that has been developed before
you described 1002 install instead of 1004
why did you have developed new driver
system should upward compatibel so that even a driver downloaded years ago should work
is there any system relevant code that the driver contains
tried now two times with different machines to install the driver with system 8 up to now no succes
our machine is disturbed at the moment so that we cant download the newese driver
is the reason really the missing new driver
why does system 8 doesn`t recognize drver that works with system 7
Windows 8 enforces digital signatures.
To disable them do this before installing the drivers.
[quote]Why should a driver install that has been developed before
system should upward compatibel so that even a driver downloaded years ago should work[/quote]Only the new driver version 1.0.0.2 works well with the new operating systems such as Windows 8 etc.
The vendor of the old driver version 1.0.0.6 (dated 19/12/2007) is Microchip.
The vendor of the new driver version 1.0.0.2 (dated 24/08/2009) is Microsoft.
have a driver which was downloaded 4 years ago
so your answer cant be the reason
there should be another advice
cab the hardware be defect havent the leds as they should be
nice day
possibel that you sent us the newest driver
kind regards
The newest driver is version 1.0.0.2.
You can download it from Velleman website.
For more info, please see this thread:
viewtopic.php?f=3&t=9239
Have driver version 3.0.0.1
where do get drver 4.0.0.1 when you say there are two versions 2007 2010
when did you publish driver 4.0.0.1
what do you mean with install driver just copied the driver to two folders
where do they have to be located
thank nice day
The latest DLL version is 4.0.0.0.
You’ll get it by downloading the package “K8061 driver update v4.0.0.0” from: velleman.eu/support/download … 8061&type=
The latest K8061.DLL version 4.0.0.0 is in the subfolder \K8061_DLL_v4.0.0.0 of the downloaded package.
When downloaded and extracted the package, you should install the driver from the subfolder \K8061Driver_v1.0.0.2
When installed, use the device manager to check the driver v1.0.0.2 is installed.
With the new driver v1.0.0.2 you have to use this new DLL version 4.0.0.0.
Here you can download detailed step-by-step instructions how to install the USB driver in Windows 7, 8 and 8.1: box.com/s/vh9olqyx3idhhxn8ujwm
The instructions are for other product but the installation principle is applicable for K8061 too.
What do you mean with install driver
copied the actaual driver to folder
where should the driver be copied to which folders
salutation
[quote]What do you mean with install driver[/quote] Please see my previous post to find that info.
Extract the downloaded zip file to any folder.
When installing the driver, you have to browse to this folder.
Hallo , es gibt immer wieder große Probleme mit der Installation des Treibers K8061 unter Win 7-8-10 . Vor allem wenn das dazugehörige Programm auf einem Kundenrechner instaliert wird der sich nicht vor Ort befindet . Ist ein signierter Treiber verfügbar ? Ist es nicht möglich den Treiber zu signieren ? Würde mir sehr helfen .
Danke schon mal für die Antwort .
Roland
