I would like to use my k8061 on a Windows 7 x64
After searching on Google for hours I still haven’t found
drivers and/or example software which work.
Are there drivers? Or is there something else I can do
to let my k8061 work again?
thank you
Roy van Marrewijk
VEL436
January 5, 2010, 6:49pm
2
Download the Vistapack: velleman.eu/downloads/files/ … 2007v1.zip
There is the driver version 6.0.1.0 you can use in Windows 7 x64.
After installing this driver you can only use the DLL and the example programs of the Vistapack.
Thank you for the answer…!!
When I try to connect the k8061 with
the VB.NET (2005) i get the message CPU fail and
USB connected.
is there an explanation for this?
VEL436
January 26, 2010, 5:53pm
4
Does the K8061 work with any of the compiled demo programs in the Vistapack?
E.g. the K8061_Demo.exe in the \Delphi folder.
no the Delphi .exe doesn’t work either…
I’m also pretty sure that the board is working, because it did a half year ago
with Windows XP.
Thank you for the quick reaction
VEL436
January 27, 2010, 10:36am
6
Is the RUN LED LD12 flashing when only the power adaptor is connected?
No it didden’t
I changed the + and -, and now it works
Thank you!!!
VEL436
January 27, 2010, 5:44pm
8
Indeed, there is a reverse voltage protection diode on the board.
